It is currently Thu Aug 07, 2025 8:45 pm
 Post subject: Truss Rod Jig
PostPosted: Fri Jun 12, 2009 1:54 am
I need a truss rod jig for a neck that has already been cut to shape. Its the same thickness all around. Anyone have such an animal that might be copied? It woudn't matter if it is designed to work with a router or dado.
Many Thanks!
B Merritt
bmerritt811@yahoo.com
 Post subject: Re: Truss Rod Jig
PostPosted: Fri Jun 12, 2009 4:28 am
Hey B Merrit, (first name would be good)
For a one off rod trench in a finished neck I just use a couple of strips of ply and a template collar on a lam trimmer. Attached are some images of one I have done just recently. You will notice that this neck is heelless which does make life a little easier but the same technique can be used for a heeled neck you just need to clamp it so it will sit still.
As you will see the truss rod in this neck had been installed off centre and the rod was just a piece of flat bar laid on side anyhow. I remove the FB and this is what I found.
I removed the old rod and cleaned up the FB surface with a sanding board.
I set up the strips of scrap ply so I could rout out the original truss rod trench and reposition it in the centre of neck shaft only the slot would be wider and much deeper than the original. The scrap ply is carefully positioned and held in place with double sided tape and a few panel pins punched below the surface of the ply.
The new wider deeper trench was then refilled by gluing in a fillet of hardwood (local jarrah) and the neck was set up with the ply once again only this time stops were added at each end and the gap was narrowed so the new trench would be a snug fit for a two way adjustable rod.
With a bit of clean up the new truss rod was installed.
And then a fillet was glued in place and leveled and a centre line marked ready for a new FB to be glued in place. The old FB can be seen to the far left in the next image, it was bent like a banana.
All done 8-)
Whoops, just realised that the last image is actually of the glued in fillet before the truss rod trench was routed. Can't find the image I want to post right now so that one will do :D I'm sure you get the idea [:Y:] 8-)
Have fun.
PostPosted: Fri Jun 12, 2009 9:26 pm
First name: Darryl
Last Name: Young
State: AR
Good ideas Kim.....thanks for posting.
PostPosted: Sun Jun 14, 2009 10:12 am
Thanks Darryl,
Glad someone found my post worth while. I guess the challenge one faces cutting a slot into a shaped and finished neck is not really something one needs to think about until they happen across a reason to do it. For some reason that has happened to me a few times, I must have been pretty bad in the last life. :D
PostPosted: Sun Jun 14, 2009 11:42 am
I'm also checking this thread out because I need to cut a slot in an old parlor I'm rebuilding that never had a rod. So this is perfect timing for me.
Thanks Kim for taking the time to post up these pics!
Yeah, karma's a ich ain't it! laughing6-hehe
Joe
PostPosted: Sun Jun 14, 2009 1:48 pm
Sorry for the late reply,I've been sort of out of pocket and slow to reply - my apologies. Thanks for the common sense idea and photos. I don't know why I didn't think of it myself ! It did work well. I appreciate the input.
Byron
aka
bmerritt811 :oops:
Users browsing this forum: kfish and 7 guests
